velocity inlet boundary
Old   May 4, 2001, 04:08
Default velocity inlet boundary
x.tang
Hi,everyone. i have the measured data, gas temperature (1500 K) and the gas veolcity (30 m/s). I want to set the measured data als velocity inlet boundary. The problem is: the velocity would be set 30 m/s (1500 K) or i should change the measured velocity (1500 K) into a standard state velocity (273 K) as the velocity magnitude. thank you in advance.
Old   May 4, 2001, 09:11
Default Re: velocity inlet boundary
Xiao Hu
I don't know why velocity would have to do with temperature? I think you need to specify velocity and temperature if you are solving compressible flow. For incompressible, temperature inlet is necessary only if you solve energy equation as well. By the way, what do you mean by 'a standard state velocity'?
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 18:42
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 19:23
