May 7, 2001, 11:16 |
Fluent 5.4 and Linux kernel 2.4
Hi there
We have recently installed kernel 2.4 on a Redhat 7.0 system. Since this I have had trouble getting parallel (multiple Linux PC's) runs started. My problem appears when trying to read (partition) the grid in the Linux parallel solver. I use a sliding mesh. When trying to import into the parallel solver using Metis, I get the following: "... Error: prf-set-var: invalid flonum Error Object: (0) Cells section: missing closing or open parathesis..." Has anybody experienced similar problems? thanks hp |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
FLUENT in Linux | L3munoz | Hardware | 4 | October 29, 2009 04:58 |
Parallel Fluent on Linux clusters | Chengwang Lei | FLUENT | 3 | November 24, 2004 02:05 |
Which version of Red Hat Linux for Fluent 5.4??? | Steve Howell | FLUENT | 6 | August 22, 2001 09:49 |
Can FLUENT run under Linux with 2 Gb of RAM? | Paul Gregory | FLUENT | 0 | February 13, 2001 20:10 |
