How to smoothing a layer in Mrf
Old   May 30, 2001, 12:18
Default How to smoothing a layer in Mrf
rafi friend
hello, ive a problem. when i use mrf method and gridding separately, there's a layer between two. is it always like that?. check it out on http://www.geocities.com/h_saryono/S...pimnas/DPM.htm
Old   May 30, 2001, 15:28
Default Re: How to smoothing a layer in Mrf
K. Tsai
The particles are tracked in each zone using its local relative velocity instead of absolute velocity. You can change the tracking velocity to be the absolute one using the text menu. That probably won't look quite right eigher since some particles will stop at the impeller, but that's the best you can get with MRF.
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 20:05
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
[snappyHexMesh] I wonder, how do I mesh a car? MadsR OpenFOAM Meshing & Mesh Conversion 0 May 2, 2011 15:39
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
