Home > Forums > FLUENT
Internal Thicknesses in 3-D
Old   May 14, 2001, 10:12
Default Internal Thicknesses in 3-D
J. Weiler
I am dealing with the use of flow straighteners in a 3-D pipe bend. In the 2-D model, I simply used edges as the straighteners and prescribed a wall thickness in Fluent as part of my boundary conditions. However, I have had no success in employing a thickness for the straighteners in my 3-D model. The only options available are for a roughness constant and a roughness thickness, which I tried, but had little success. I ran the simulation without the straighteners and my solution was accurate, so I know the model should work. I am unsure about how to prescribe the thickness of the straighteners in Fluent. I welcome any suggestions.
Justin
Old   May 15, 2001, 22:56
Default Re: Internal Thicknesses in 3-D
Lanre
The only specification for wall thickness as a BC in FLUENT 5 is when you need to specify a thickness for the heat conduction calculation.
Is the thickness not defined by your geometry? You can: -create 3D thickness for the straighteners, or -define zero-thickness walls to avoid high aspect ratio cells.
Thread Tools
Trackbacks are On
Internal boundary problem stefanke OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 May 24, 2011 02:21
Fluent Mesh to OpenFoam: Internal Surface has to be a wall sebastian OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 6 October 21, 2010 04:36
mapFields : internal edges Gearb0x OpenFOAM Running, Solving & CFD 3 April 19, 2010 09:02
TGridFluent mesh with internal by prism layer and internal face for diagnostic sponiar OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 March 30, 2009 15:02
how to get fluid internal internal energy vbk FLUENT 0 December 17, 2007 02:54
