May 14, 2001, 10:12 |
Internal Thicknesses in 3-D
I am dealing with the use of flow straighteners in a 3-D pipe bend. In the 2-D model, I simply used edges as the straighteners and prescribed a wall thickness in Fluent as part of my boundary conditions. However, I have had no success in employing a thickness for the straighteners in my 3-D model. The only options available are for a roughness constant and a roughness thickness, which I tried, but had little success. I ran the simulation without the straighteners and my solution was accurate, so I know the model should work. I am unsure about how to prescribe the thickness of the straighteners in Fluent. I welcome any suggestions.
Justin |
May 15, 2001, 22:56 |
Re: Internal Thicknesses in 3-D
The only specification for wall thickness as a BC in FLUENT 5 is when you need to specify a thickness for the heat conduction calculation.
Is the thickness not defined by your geometry? You can: -create 3D thickness for the straighteners, or -define zero-thickness walls to avoid high aspect ratio cells. |
[Commercial meshers] Internal boundary problem | stefanke | OpenFOAM Meshing & Mesh Conversion | 2 | May 24, 2011 02:21 |
[Commercial meshers] Fluent Mesh to OpenFoam: Internal Surface has to be a wall | sebastian | OpenFOAM Meshing & Mesh Conversion | 6 | October 21, 2010 04:36 |
mapFields : internal edges | Gearb0x | OpenFOAM Running, Solving & CFD | 3 | April 19, 2010 09:02 |
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic | sponiar | OpenFOAM Meshing & Mesh Conversion | 2 | March 30, 2009 15:02 |
how to get fluid internal internal energy | vbk | FLUENT | 0 | December 17, 2007 01:54 |
