Particle tracking using fluent 5
Old   May 29, 2001, 11:52
Default Particle tracking using fluent 5
John Beveridge
I am using fluent 5 to track particles down a 0.19m diameter pipe with a velocity of 0.6 m/s. Is there a limit to the size of particles I can accurately measure (i.e. 10% of diameter)? and do they have to be positioned at a certain distance away from the pipe wall (i.e. 0.5 diameter)?
Any help in this matter would be most appreciated. Thanks, John
Old   May 30, 2001, 12:54
Default Re: Particle tracking using fluent 5
rafi friend
i think one thing you must do is setting the inlet sources completely (from surface, or from file, single etc. read fluent manual). but you can guess if you specify particle inlet with diameter 0.5 mm and 0.4 mm away from pipe wall.
Old   June 4, 2001, 06:25
John Beveridge
Thanks Rafi, but I am really after the maximum size that a particle can be - obviously a particle can't be modelled well if it is 99% of the diameter of the pipeline. So what is the biggest it can be, and still be moved to a reasonable degree?
Old   June 6, 2001, 10:08
Althea
Hello John,
Assuming that Lagrangian particle tracking is used (as per Fluent 4) then the volume fraction limit usually advised (in the papers I've read - sorry I have no references to hand) is about 12%. I would therefore translate this into a single particle with a diameter of less than 12% of the pipe diameter, or if several particles are simulated, the sum of their diameters should be less than 12% of the pipe diameter.
As is always the case, it is useful to have some reliable experimental data (or even hand calcs.) of a similar type of system, with which to compare the CFD to check you are in the right ballpark.
I hope this helps.
Regards
Althea
Old   June 6, 2001, 10:10
John Beveridge
thanks for that! I appreciate your help in this matter
Old   June 13, 2001, 12:53
HGG
Hi,Althea, If case is a converged-diverged pipe, do you mean the translated diameter should be less than 12% of diameter of samll section(throat of constricting part)?
thanks
Old   June 14, 2001, 06:19
Althea
Yes, that seems reasonable. Althea
Steady state particle tracking? John CFX 5 August 11, 2013 19:34
Particle Tracking Batis CFX 2 October 6, 2010 16:20
restarting lagrange (particle tracking) simulation dbdias CFX 0 September 22, 2007 20:26
Big Biomass Particle Tracking in FLUENT Jacklyn FLUENT 8 May 14, 2007 11:28
particle tracking collection tank Neser CFX 1 June 1, 2006 11:06
