June 10, 2001, 08:32 |
about error message in fluent
When I simulate a flow in fluent 5.4,there is error message sometimes. Error:Floating point error:invalid number Error object) Then the iteration is stopped.If I click inteate button,the iteration continues. Would you like to tell me how this problem exists? Thank you! |
June 10, 2001, 21:13 |
Re: about error message in fluent
I have expericenced similiar case like you. In my opinion, your problem may be caused by numerically stiff situation. My suggestion is to check your grid system and skewness again. Also, check if your initialized value is proper and find a proper under relaxation factor.
I've solved that problem with these procedures metioned above. May this answer helpful. |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 04:16 |
A Problem of Fluent Interpreted UDF: parse error | knight | Fluent UDF and Scheme Programming | 25 | August 16, 2018 10:26 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
Compared MRFSimpleFoam and Fluent in a centrifugal pump! | renyun0511 | OpenFOAM Running, Solving & CFD | 8 | July 6, 2010 06:24 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
