Periodic
Old   June 9, 2001, 02:19
Default Periodic
Ting Lik Ho
I am facing problem when I create the periodic boundary type - can not export to Fluent.
Is it possible that my meshing is incorrect?
I am doing 2D analysis.
Thanks.
Old   June 10, 2001, 23:54
Default Re: Periodic
Kuochen
Make sure the mesh on the periodic boundaries are linked!
Old   June 11, 2001, 02:43
Martin
Also make sure that you specify the periodic faces as a wall and not as periodic in Gambit. When you import it into Fluent change them back to periodic using grid/modify-zone/make-periodic.
Old   June 14, 2001, 11:42
Ting Lik Ho
Thanks a lot for the advice.
I have solved the problem. The error occurs because of the geometry - I import the geometry into the Gambit by the acis format. When I create/draw the geomtery in Gambit itself, there is no problem for me to create the periodic boundary type.
Periodic boundary condition Arif FLUENT 3 March 9, 2017 01:18
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 02:18
Why can't I make the boundaries periodic? Alina FLUENT 5 April 12, 2012 14:06
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 28, 2010 23:32
[ICEM] Specifying Periodic Vertices Causes Mesh Overlap Josh ANSYS Meshing & Geometry 10 July 8, 2010 02:39
