Free Surface Gravity Driven Flow
Old   June 13, 2001, 15:12
Default Free Surface Gravity Driven Flow
Rupp Carriveau
I am trying to solve a simple gravity driven funnel flow in Fluent. My mesh geometry is a simple cone, (upside down lampshade). I have specified that both the inlet and outlet have zero gauge pressure (both open to atmosphere)---(this flow is purely gravity driven). As this funnel drains I wish the water level to remain constant as if exactly what is drained is re-fed to the top. I have set the top and bottom of my cone as pressure inlet and outlets respectively, and set my cone structure simply as a wall. When I solve this flow the pressures vary so minutely from zero in between the 2 boundary conditions, and, velocity at the outlet is not even close to V=(2gh)^0.5, which it should at least be in the neighbourhood of. I have gravity turned on in the model, I checked most other things, can anyone suggest what I am missing in this simple problem?
Thanks so much,
Rupp.
Old   June 13, 2001, 21:40
Default Re: Free Surface Gravity Driven Flow
rafat
Have you tried to apply body weighted coupling.
Old   June 14, 2001, 15:03
Rupp
Yes,
Results unfortunately remain unchanged.
Thanks for the response,
Rupp.
Old   June 14, 2001, 16:53
Scott Whitney
There is a small mistake in your logic. You forgot the pressure from the water on top of the bottom exit. For example if the funnel is 1m high, and the top inlet is set to 0 guage pressure, then the bottom outlet must be set to: density*gravity*height=-(1000kg/m^3)*(-9.81m/s^2)*(1m)=-9810 Pa guage
Note that gravity is negative in this case. I tried the solution and it works perfectly when the water pressure is included, but fails if both openings are set to the same pressure.
Old   June 14, 2001, 16:54
Scott Whitney
Oops, I put an extra negative sign accidently at the front of the formula. It should read:
density*gravity*height=(1000)*(-9.81)*1=-9810 Pa guage
Sorry about the typo.
Thermocapillary free surface flow zakifoam OpenFOAM Running, Solving & CFD 10 December 12, 2016 11:44
Free surface flow over a bump qtian OpenFOAM Running, Solving & CFD 17 August 10, 2010 10:15
CFX gravity driven free surface flow tutorial mechovator CFX 37 July 27, 2009 10:28
free surface flow same as FSI??? Ken CFX 1 February 18, 2008 19:43
incompressible free surface flow past cylinder vineet FLUENT 2 April 1, 2002 05:56
