Home > Forums > FLUENT
about two fraction units
Old   June 14, 2001, 20:51
Default about two fraction units
appleyy
hi,I have a question:in my diffusion model,when I have done the iteration,I want to see some cocentration of each species,but when I use two different units of mass fraction and mole fraction,the solutions are the same(the numbers in each nodes in mass fraction are the same as those in mole fraction).I do not know the reason,are these two units same? thank for your help
Old   June 16, 2001, 02:27
Default Re: about two fraction units
Jin-Wook LEE
No. Mole fraction is volume fraction.
If the molecular weights of two species are the same, then mole fraction and mass fraction are the same.
Anyway, the trend(pattern) of mole fraction and mass fraction is always the same. The difference is only absolute value.
Sincerely, Jinwook
Old   June 16, 2001, 03:48
apple
I know only when the molecular weights of the species are same,the two units are same. But in my solution ,the absolute values are the same as well as the trend. Can you help me finding the probably reasons? thank you
Old   June 18, 2001, 05:54
Jin-Wook LEE
If molecular weights of two species are the same, absolute values of mass fraction and mole fraction, as well as the trend, should be the same.
Otherwise(if molecular weights are not the same), it is, as far as my experience, impossible solution and I never think such situation occur Fluent's simulation result. It's only post processing.
Sincerely, Jinwook
Old   June 18, 2001, 22:00
apple
Sorry,I've made a mistake.The absolute values are not the same exactly,but they are so low that the difference between them are uneasy to see.Thank you for your help.
Thread Tools
Trackbacks are On
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
interDyMFoam - change in volume fraction gopala OpenFOAM Running, Solving & CFD 0 April 27, 2009 10:46
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
