Home > Forums > FLUENT
Wind Tunnel grid
Old   June 20, 2001, 13:23
Default Re: Wind Tunnel grid
  #21
Garvin Forrester
That makes sense. You mentioned "all around the wall", you mean from the floor right. Are my B.C's O.K. Po,To at inlet: no-slip walls, slip floor: pressure ratio at exit.
Old   June 20, 2001, 13:45
  #22
John C. Chien
(1). If I were you, I would just use the simple non-slip boundary condition for all walls first. Just to see how it works. (2). If you have moving wall (floor) or something like that, you can always change it and check the effect. (3). I would also use the simple velocity inlet condition and downstream exit (parallel condition) condition first, and check the result. (4). Using inlet total pressure and exit static pressure conditions is also a standard approach. In your low speed flow, you can use either set of conditions.
Old   June 20, 2001, 18:42
  #23
Trac
So it's a ground effect problem - but you're modelling a slip wall in CFD when the wind tunnel wall won't be slip. Why not model exactly what's happening in the wind tunnel? If you want to get the same results from the wind tunnel as for the CFD you need to model the *exact* same thing. What is the ground doing in the wind tunnel?
Old   June 21, 2001, 08:47
  #24
Garvin Forrester
The grouind is stationery. Eventually I want to place a model in the tunnel. I have the Velocity and dynamic pressure in the section and boundary layer data. I agree with having no-slip on the walls. It must of been a typo. Any suggestions on time-step and CFL? I'm converging at over 3000 iterations(multi-grid). Does this sound right? This is my first time doing an internal flow problem.
Old   June 21, 2001, 13:34
  #25
John C. Chien
(1). The same story again. When you simulate a flow problem by CFD, remember to get the "mesh independent" solution. (2). Mesh refinement is required when dealing with viscous flows. (3). By the way, you could try to compute the flat plate flow ,say 200 FT long, and check your result against the test data or formula given in the Schlichting's book (boundary layer theory). (4). If you can't get the flat plate flow right, then don't expect to get good results for your wind tunnel.
Old   June 22, 2001, 07:11
  #26
Garvin Forrester
Thank you.
Thread Tools
Trackbacks are On
flow in cyclic wind tunnel yogesh@cfd Main CFD Forum 0 November 8, 2010 05:28
grid dependence, flow over a cylinder (inside a wind tunnel) dfmona CFX 9 March 21, 2010 20:47
wind tunnel results vs fluent pixie Main CFD Forum 1 August 20, 2009 08:02
Virtual Wind Tunnel in FLUENT ND FLUENT 0 April 7, 2006 07:43
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
