June 27, 2001, 04:45 |
Any suggestions?
I want to model a turbine wheel (similar to a pelton type) which rotates and scoops up fluid which lies at the bottom. Above the water is air. It is a 2-D model but I am not sure how to approach the problem. Any suggestions on which models to use or how to account for the two phases. If there is anything like a simple solution then that is what I am looking for?
Thanks |
June 27, 2001, 14:28 |
Re: Any suggestions?
VOF + sliding mesh in FLUENT 5.4 or greater.
June 29, 2001, 06:07 |
What is your ultimate goal?
June 29, 2001, 07:21 |
I want to determine the torque on the turbine wheel for different geometries (i.e. change the shape of the buckets and look at the required torque)
Suggestions for simplyfying propeller geometry? | mmn1239 | ANSYS | 0 | May 9, 2011 14:44 |
Suggestions regarding derivative calculations | RameshK | Main CFD Forum | 0 | March 3, 2011 06:02 |
[ICEM] Suggestions for my Grid | Josh | ANSYS Meshing & Geometry | 13 | October 27, 2010 04:48 |
Suggestions on Mesh and Schemes for MRFSimpleFoam | mixer | OpenFOAM Running, Solving & CFD | 3 | September 1, 2009 10:50 |
Please Suggestions about source code uploading | Michail | CFD-Wiki | 8 | September 21, 2005 07:15 |
