Post Processing
Old   June 27, 2001, 11:50
Default Post Processing
Sorend
I'm in need of creating a conical surface for post processing purposes. Is it possible in Fluent? If so, how?
Thanks. Sorend
Old   June 27, 2001, 14:30
Default Re: Post Processing
Lanre
Use quadric plane! Surface->Quadric... and Type: Quadric.
Old   June 28, 2001, 03:48
Flav
And by the way, how would you create a triangular surface for Postprocessing ?
Old   June 28, 2001, 09:43
Lanre
Here's a reference for the quadrics: http://www.geom.umn.edu/docs/referen...as/node61.html
For a triangle, you will have to iso-clip (a couple of times) a plane/surface to x, y or z coordinates. If x, y and z don't work you can always create your own coordinates using Custom Field Functions.
Ansys Post processing ano999 ANSYS 1 May 27, 2011 16:24
NO model vs post processing in coal combustion,CFX sakalido CFX 1 April 15, 2011 14:07
post processing for KIVA dirga Main CFD Forum 5 April 23, 2009 10:58
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 20:51
