Home > Forums > FLUENT
plotting pressure
Old   July 2, 2001, 06:48
Default plotting pressure
aninbo
Hello everybody,
we are studying the fluid dynamic field of a wing in a wind tunnel: we have to plot the pressure just on the middle section, but we don't know how we can do this directly by Fluent. Any suggestion?
Thanks
Old   July 2, 2001, 21:17
Default Re: plotting pressure
Chetan Kadakia
Display->Contours: select pressure in the window and static pressure in the 2nd window.
If your simulation is 2d, then just select the fluid zone in the selection box.
If your simulation is 3d, you need to create an iso-surface to display contours along the plan you want to see.
Is it 2d or 3d?
Old   July 3, 2001, 04:29
aninbo
Our simulation is 3-D, but we want to plot pressure in the intersection between the wing and a middle section .
thanks
Old   July 4, 2001, 02:28
Chetan Kadakia
You need to create a plane surface. Go to Surface-->Plane Type in 3 points that are the in mid section of the plane. Leave everything else as defaults. Tyoe in a name like 'mid-section', and of course hit create. Now I think you should have a plane surface which cuts through the midsection. Select this surface when you display pressure contours (Diplay->Contours, select pressure and static pressure, hit plot). Try this and see if it works.
Thread Tools
Trackbacks are On
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
pressure BC-natural convection engahmed Main CFD Forum 0 June 16, 2010 11:38
pressure in Natural convection??? engahmed FLUENT 0 June 14, 2010 12:51
Setting pressure and velocity in inlet Asghari FLUENT 5 September 22, 2006 13:23
