July 2, 2001, 04:35 |
Normal Vector on Curved Surfaces
For a radial fan i have to calculate the rate of mechanical work performed at moving walls, which are fixed in the relative system. To calculate this work i need the compute the unit normal vector on the wall area elements. Normally, these elements have curved surfaces (eg. blades). How can i access these normal vectors with a UDF ? Or is it possible do compute them with a simple custom field function ?
"wall normal velocity" on moving surfaces (FSI) | andey | CFX | 6 | February 24, 2010 02:37 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 01:30 |
Sampling curved surfaces | sega | OpenFOAM Post-Processing | 0 | July 12, 2009 11:40 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
Law of the wall on curved surfaces | Rasputin | Main CFD Forum | 3 | November 2, 1998 09:28 |
