July 5, 2001, 10:16 |
chemical reaction problem
Hi ! I'm student in France and I TRY to use Fluent… I'd like to simulate a quite complex reaction. So, I've to use an UDF for generating sources. To understand how to proceed I try with a simple reaction just below :
A + B -> C with r (kg/m3.s) = 1017 exp (-105/RT) . CA.CB I've compared the results obtained with the reactions panel and those obtained with UDFs. In order to obtain the same results I've to multiply the preexponential factor A by 100 (so 1019) in my UDFs model. Can anybody tell me the reason? I'm thanking you a lot for any suggestion. |
July 5, 2001, 13:12 |
Re: chemical reaction problem
I've had similar problems with chemical reactions and the Arrhenius model. Might be a problem with your units - check them. good luck, Paul
March 14, 2013, 14:56 |
arrhenius constants units
hossam ali
hi i want to know the units of arrhenius constants applied in fluent
thanks |
problem about porous media and surface reaction | Jeff Lee | FLUENT | 3 | November 24, 2011 13:46 |
Problem implementing DETAILED REACTION MECHANISM | Phil | FLUENT | 0 | May 5, 2007 11:38 |
Simpler Chemical Reaction Problem | Sam | Siemens | 7 | February 7, 2006 09:28 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
UDF : Chemical Reaction in Catalytic Converter | adhimac | FLUENT | 1 | March 27, 2001 14:04 |
