Home > Forums > FLUENT
Problem of DPM
Old   July 10, 2001, 07:52
Default Problem of DPM
you
Dear everyone:
I am using DPM method to simulate drops distribution in a compartment. The residuals are always oscillatory and don't converge. Could you please tell me how to make my solution convergence ? Thank you very much for your help.
I am looking forward to your reply.
With best regards,
You
Old   July 10, 2001, 08:40
Default Re: Problem of DPM
Livo
I have exactly the same problem if it is any consolation!
Old   July 10, 2001, 08:52
you
hi
Old   July 11, 2001, 03:17
Alain
Hi you,
can you give more detail on your case : coupled or segregated solver ? two way coupled dpm calculation or not ? with stochastic particle track ? does the calculation for the continuous phase converge without particle, ...
best regards
Alain
Old   July 11, 2001, 03:37
you
Hi Alain,
Thank you very much for your reply. I am using segregated solver and coupled dpm calculation with stochastic particle track. The calculation for the continuous phase converges without particle. The drop diameter is 1.2 mm.
Do you provide enough information ?
best regards, You
Old   July 11, 2001, 05:34
Christian
Can it have something to do with how often you inject particles ?
Christian
Old   July 11, 2001, 10:34
you
Thank you very much for your reply. I have tried inject particles every 5 to 20 iterations.
With best regards, You
Old   July 12, 2001, 01:55
Jin-Wook LEE
Dear you
1) Drop diameter is fairly big compared to the general DPM application. So, I think, it's momentum source is fairly large. Because you use stochastic partilce tracking, small change in momentum source in local area(local cell) can cause fairly big effect. So, how about to try mean particle tracking(without stochastic option) ?
2) When I try DPM and convergence is difficult, I increase gas phase iteration, that is, 50~100 iteration per each DPM iteration. At that time, I set residual convergence criteria very low value, e.g., 1.e-05. Then, iteration is continued. After many iterations(at least 50~100 DPM injection iteration), I check every residual whether they are enough low or not. With this approach, in general(not every case), I was successful.
I hope that it might be helpful to you.
Sincerely, Jinwook
Old   July 12, 2001, 04:43
Alain
Dear you
I agree with jimwook.
Your lack of convergence is certainly do to stochastic tracking.
Note that this can also be the result of a physical phenomenon ! Trochastic tracking introduce implicitly a temporal term in the momentum equation due to fluctuation of the term of exchange.
This can be observed experimentaly in dense two phase flow such as pneumatic transport or fluidized bed.
Take a look at your momemtum source term and your flow pressure and velocity field. Your source term can fluctuate but your field can be steady. In this peculiar case your flow is "converged" even if your residuals remains high.
At last, if your flow diverge, you can also underrelax the source term coming from DPM.
Best regards
Alain
Old   July 13, 2001, 00:21
Jin-Wook LEE
Add to previous comment :
Increasing injection number might be helpful for convergence because momentum source of each injection is relatively small with many injection number.
Sincerely, Jinwook
Thread Tools
Trackbacks are On
DPM Output Problem (Again...) DLINSA Fluent UDF and Scheme Programming 1 March 16, 2012 01:45
Problem in DPM Harpreet FLUENT 0 July 31, 2011 09:56
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
DPM problem Jane FLUENT 4 February 20, 2004 04:24
