July 11, 2001, 12:37 |
limitations of gambit
Problem.
I am trying to create a 3-D model of a Br710 engine nacelle using Gambit 1.1, with the area modelled being the "zone". The zone consists of two inlets and a pressure outlet. With one of the inlets delivering a fire exstinguishant. What i am trying to do is build the model using segmented volumes, which are identical bar the one with the inlet for the fire extinguisher. Then once the model has been run i can rearrange the volumes to give me a different position for the inlet. However when i try to mesh together two of the most simple of shapes (like bricks) i recieve an error message saying that "the two volumes cannot be meshed as the lower topology is not consistent" Questions Can Gambit facilitate me in what i want to do? How can i create a consistent topology between two volumes? What other steps can i take to get an improved solution? Niall Lenehan QUB Belfast |
Display Modes | |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 06:22 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 07:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 13:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 09:33 |
Problem starting Gambit | ViHAR MALViYA | FLUENT | 0 | November 10, 2006 11:26 |
