limitations of gambit
Old   July 11, 2001, 11:37
Default limitations of gambit
Niall lenehan
Problem.
I am trying to create a 3-D model of a Br710 engine nacelle using Gambit 1.1, with the area modelled being the "zone". The zone consists of two inlets and a pressure outlet. With one of the inlets delivering a fire exstinguishant. What i am trying to do is build the model using segmented volumes, which are identical bar the one with the inlet for the fire extinguisher. Then once the model has been run i can rearrange the volumes to give me a different position for the inlet.
However when i try to mesh together two of the most simple of shapes (like bricks) i recieve an error message saying that "the two volumes cannot be meshed as the lower topology is not consistent"
Questions
Can Gambit facilitate me in what i want to do? How can i create a consistent topology between two volumes? What other steps can i take to get an improved solution?
Niall Lenehan
QUB
Belfast
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
Problem starting Gambit ViHAR MALViYA FLUENT 0 November 10, 2006 10:26
