Fluent -> Tecplot
Old   July 27, 2001, 15:48
Default Fluent -> Tecplot
Alberto
Hello all,
I would like to know how can I read on Tecplot 8.0 data exported from Fluent.
Thanks.
Old   July 27, 2001, 17:43
Default Re: Fluent -> Tecplot
Jeff
There is an option in FLUENT, "Export ...", you can export your results in Tecplot format.
Old   July 28, 2001, 10:07
Alberto
OK, I know that Fluent can export a Tecplot compatible file, but how can I read it on Tecplot?
Which file type should I select on Tecplot's import process?
Thanks.
Old   July 28, 2001, 13:15
Jeff
From "File->Load DataFile(s)...". I can do this for the data generated by FLUENT. Please tell me what's the error message you meet. I am sure you can make it.
Tecplot with fluent Rafael FLUENT 7 February 9, 2018 00:57
how to read fluent Cl and Cd data in tecplot lalit kumar FLUENT 0 August 29, 2010 07:47
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
chemkin -> fluent Tomasz ochrymiuk Main CFD Forum 0 March 16, 2000 05:55
chemkin -> fluent Tomasz Ochrymiuk FLUENT 0 March 16, 2000 05:11
