Home > Forums > FLUENT
merging mesh files
Old   July 31, 2001, 02:18
Default merging mesh files
hi, In the tutorial regarding stator-rotor interaction using sliding mesh capability,it is told to merge two mesh files using Tgrid.Can this not be done using Gambit itself and if not, why?
Old   August 1, 2001, 09:27
Default Re: merging mesh files
TGrid will execute the program "tfilter tmerge2(or 3)d" and Gambit does not.
You can run the command from the command line if you wish, or utilise the TGrid GUI. If the origin of the multiple meshes are unique to each part, the command line option is better since you can provide translation and rotation information prior to merging the multiple meshes.
Type "tfilter tmerge3d" at the command line and follow the prompts.
Thread Tools
Trackbacks are On
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
merging two faces without losing mesh mayur_ ANSYS Meshing & Geometry 1 July 13, 2010 01:10
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
Importing mesh files from Ansys into Gambit Srinivas FLUENT 2 August 6, 2002 10:02
