Turbulence Model?
Old   August 2, 2001, 14:02
Default Turbulence Model?
siswara
Hi , right now I'm modelling 3D centrifugal fan. I had difficulties to determine what turbulence model which gives accurate and reliable results.
Any suggestions?
Old   August 3, 2001, 21:37
Default Re: Turbulence Model?
chiseung
In my opinion, finding related papers or experimnetal data would be better.
P.S. Reynolds Stress Model is the best "generally".
Old   August 18, 2001, 14:33
john
goblok , ngono wae gak iso , dancuk koen, asu
Old   August 19, 2001, 02:25
Chetan Kadakia
Which language is John speaking in?
All the models work but they all suck.
It all depends on your problem, computer power, and desired results.
RSM is good, but I think LES is better if the mesh is fine enough. I think of LES as the next closest thing to DNS.
k-epsilon models and spallart allarmus also work well for certain flows.
What type of flow are you modelling, how much processor power and memory do you have, and what is your end goal?
Old   August 19, 2001, 12:51
John C. Chien
(1). I think, you are right. (2).Using my definition of CFD, you will have to do "mathematical modeling". (3). And "Modeling" is not "select an option". You will have to fool around with your problem and the corresponding model(ing). (4). So, you don't expect to get accurate results by just picking an option. (unless it has been modelled, fine tuned and validated for your problem)
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
Fan heater model: what turbulence source to use? andy20 CFX 7 March 3, 2008 16:42
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
