August 15, 2001, 20:40 |
ask for you help in GAMBIT
hi Fluent-user: I am a newer in Fluent.When i simulate a furnace,i meet the problem that the furnace is hollow,and there are much heater in it,when i creat the furnace by gambit,how i deal with the heater?(if substract the heater from the furnace?) i hope you help,thank you!
sincerely hanjun |
August 16, 2001, 01:57 |
Re: ask for you help in GAMBIT
If you substract the heater from the furnace then the furnace is deleted. I think you should split (bidirect) the heater from the furnace.
Armin |
August 16, 2001, 08:41 |
let me try it,but i hope the user who master fluent can advice me on it.
Converting Fluent mesh files to Gambit neutral files | samuelkc | ANSYS Meshing & Geometry | 9 | April 21, 2021 06:28 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
Gambit batch - kill "Startup" box how? | Chris Bailey | FLUENT | 2 | February 23, 2005 09:05 |
