August 14, 2001, 18:41 |
Thin Surface in Gambit
Hi all,
Why Gambit didn't recognize a surface that I had set to wall as a thin surface? Gambit simply ignores it when I export the .msh file. I want to use the Fluent 5 solver. So, anyone got any hint? Regards, cfd guy |
August 16, 2001, 10:40 |
Re: Thin Surface in Gambit
First, please check if the surface belongs to volumes. If the surface is standalone, then you can't export it. Second, if the surface is "of" volumes, then if you don't mesh it, again you can't export it.
Have a nice day. |
August 16, 2001, 12:47 |
Thanks Jerry for answering,
As a new user I must say that Gambit didn't export the thin surface defined as WALL. I was meshing my volume with tets, is this might be the problem? Regards, cfd guy |
surface planes in gambit | falak | FLUENT | 11 | September 12, 2014 15:38 |
ICEM CFD 5.0 (Hexa) - Internal Wall/Thin Surface | James Date | CFX | 3 | August 10, 2012 04:47 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
How to set a thin surface using CFX4.4? | paul | CFX | 9 | January 19, 2004 21:53 |
sphere in a free surface (thin film)flow | Vasu Veerapaneni | Main CFD Forum | 0 | September 15, 1998 17:32 |
