Reference value
Old   August 22, 2001, 04:29
Default Reference value
Ting Lik Ho
Could someone tell me more about the reference value in the Fluent? I found that it is going to affect my result (x-y plot) if I change the reference value like velocity.
Old   August 22, 2001, 12:00
Default Re: Reference value
KH
I suggest you have to specify you question with further details. In some cases yes, for e.g. Boussinesq approximation for bouyancy.
Old   August 22, 2001, 14:36
Mary
Temperature? Pressure? .....which reference value are you speaking of?
Old   August 23, 2001, 08:38
Ting Lik Ho
I just want to kow how to use the command in Report>Reference value.
Old   August 23, 2001, 16:54
Dave
when changing results from to coefficients for example pressure to Cp the reference value enered here will be used to calculate the dynamic prssure and therefore will have a large effect on the results.
these should generally reflect the freestream values if these are known.
Old   August 25, 2001, 21:02
Jim Clancy
Even for Cd computation, refernce area will affect.
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 04:28
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
Building OpenFoAm on SGI Altix 64bits anne OpenFOAM Installation 8 June 15, 2006 09:27
