Time step reduced in 3 cells
Old   August 31, 2001, 10:26
Default Time step reduced in 3 cells
jie
Hello, Sir,
I found that I came upon one problem with my simulation. However , the Fluent told me that : Time Step reduced in 3 cells . And the information went all the down the simulation. How can I solve it? THanks very much.
Jie
Old   September 3, 2001, 05:04
Default Re: Time step reduced in 3 cells
Ignacio
(1). I think, when the programmer was doing the code checkout, he printed the message after some calculations or the if statement, so
that he could determine whether the logic was executed or not. (2). My feeling is, it is probably not intended for the user of the code. It is
telling the programmer that something has happened. (most likely, it is heading in the wrong direction, the solution is diverging.)
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
