-   -   Graphical image of a species flow (http://www.cfd-online.com/Forums/fluent/28865-graphical-image-species-flow.html)
Rajeev Kumar Singh August 29, 2001 02:10
Hi Everybody!
I am calculating residence time distribution for a flow in tundish. For this I am using species transport model. I have patched the species at the inlet and then I am monitoring flow rate of mass fraction of the non-reacting species at the outlet. Finally the rtd curve is generated as given in Levenspiel's book.
Along with this I want to take the graphical image at different time intervals. These images should show me the front of species as it is moving and getting mixed up in the flow. I tried creating iso-value surfaces. But that does not look good. Contour plots could be got only on known surfaces. I would like to see the cloud of the species in 3-D moving inside the flow.
Can anyone help me ?
Thanks in advance
Best Regards
M.A.SALEHI September 23, 2001 04:10
Re: Graphical image of a species flow
DEAR,SIR
HI,I HOPE CAN HELP TO YOU ABOUT YOUR PROBLEM,I RESEARCH ABOUT THIS,
CONTACT WITH ME
ALI SALEHI
MSc CHEMICAL ENGINEERING
