-   -   S-A y+ problem (http://www.cfd-online.com/Forums/fluent/28883-s-y-problem.html)
Andrew Parker September 3, 2001 09:55
S-A y+ problem
Dear all
I know that if I am using a k-epsilon model with near wall treatment as two-layer zonal then my y+ must be below 4 or 5. What is the y+ value that lets the S-A model work probably, I have been told that it should be between 50 and 60, is this true?
Cheers
Andy
Herve September 7, 2001 11:47
Re: S-A y+ problem
Silly question maybe, but what is the S-A model?
Herve
Andrew Parker September 9, 2001 10:35
Re: S-A y+ problem
It is the Spalart-Allmaras turbulence model that can be used in Fluent, and can be found in the define menu. I would have thought that if you where using fluent you should have spotted this.
Andy
