September 6, 2001, 09:09 |
Error when using k-e model !?
Hi, I'm simulating with Fluent the development of a flow initially at rest under EM forces.
I wrote an UDF which calculates the distribution of EM forces. However, I have some difficulties to make the solution converge to a "physical solution": I change the solver parameters, the mesh... but nothing seems to change the numerical solution. Finally, I decided to run the solution wih a k-e model instead of the laminar one. But, before the end of the first iteration, and only when using the k-e model, I have this error message: Error: > (greater-than): invalid argument [2]: wrong type [not a number] Error Object: nanq I verified that my UDF gives always correct numbers, and it is. Thanks for ideas or solutions... Mika PS: here is my UDF, as asked in a previous post. double zmaxi; double pas; int NbreAimants; double *TabAimants; int NbreElectrodes; double *TabElectrodes; real x_fluent[3]; double X[3]; double F[3]; char path[100]="/legi44p/tourn/perrin/DEA/"; /*char path[100]="/legipc65/home/perrin/DEA/";*/ char path2[100]; FILE *debug_x; /*FILE *debug_y;*/ /* FILE *count;*/ DEFINE_SOURCE(emf_x,cell,thread,dS,eqn) { int i; double z; double force[3]; double j; int it; /* permet de recuperer le nombre d'iteration */ it = (nres == 0) ? (0) : ((int) count2[nres - 1]); if(it<1) { strcpy(path2,path); if((debug_x=fopen(strcat(path2,"fluent/udf/emf7/src/debug_x"),"a"))==NULL) { fprintf(stderr,"Erreur a l'ouverture du fichier debug"); } /* strcpy(path2,path); if ((count=fopen(strcat(path2,"fluent/udf/emf7/src/count"),"r"))==NULL) { fprintf(stderr,"Erreur a l'ouverture du fichier count 1"); } fscanf(count,"%d",&compteur); fclose(count); strcpy(path2,path); if ((count=fopen(strcat(path2,"fluent/udf/emf7/src/count"),"w"))==NULL) { fprintf(stderr,"Erreur a l'ouverture du fichier count 2"); } fprintf(count,"%d",++compteur); fclose(count);*/ lect_data(); lect_aimants(); lect_electrodes(); /* récupération des points du calcul */ C_CENTROID(x_fluent,cell,thread); X[0]=x_fluent[0]*1000.0; X[1]=x_fluent[1]*1000.0; X[2]=x_fluent[2]*1000.0; z=zmini; i=0; force[0]=0; force[1]=0; force[2]=0; while(z<zmaxi) { X[2]=z; calcul_force(X); force[0]+=F[0]; force[1]+=F[1]; force[2]+=F[2]; z+=pas; i++; } j=(double)i; F[0]=force[0]/j; F[1]=force[1]/j; F[2]=force[2]/j; fprintf(debug_x,"\nX: %lf, Y: %lf, Z:%lf, force_x: %lf Fx=%f force_y: %lf FY=%fj=%lf\n",X[0],X[1],X[2],force[0],(real)F[0],force[1],(real)F[1],j); free(TabAimants); free(TabElectrodes); /* sauvegarde des valeurs dans une variable */ C_UDMI(cell,thread,0)=(real)F[0]; } else { F[0]=C_UDMI(cell,thread,0); } fclose(debug_x); return (real)F[0]; } void lect_data() { FILE *fdata; char str[25]; strcpy(path2,path); if ((fdata=fopen(strcat(path2,"fluent/udf/emf7/src/data.dat"),"r")) ==NULL) { fprintf(stderr,"Erreur a l'ouverture du fichier data.dat"); } fscanf(fdata,"%s %lf",str,&conductivite); pi=M_PI; fscanf(fdata,"%s %lf",str,&unite); fscanf(fdata,"%s %lf",str,&zmini); fscanf(fdata,"%s %lf",str,&zmaxi); fscanf(fdata,"%s %lf",str,&pas); fclose(fdata); } void lect_aimants() { FILE *faimants; int i; int j; strcpy(path2,path); if((faimants=fopen(strcat(path2,"fluent/udf/emf7/src/aimants.dat"),"r"))==NULL) { fprintf(stderr,"Erreur a l'ouverture du fichier aimants.dat"); } fscanf(faimants,"%d",&NbreAimants); TabAimants=malloc(NbreAimants*6*sizeof(double)); for(i=0;i<NbreAimants;i++) { for(j=0;j<6;j++) { fscanf(faimants,"%lf",(TabAimants+i*6+j)); } } fclose(faimants); } void lect_electrodes() { FILE *felectrodes; int i; int j; strcpy(path2,path); if((felectrodes=fopen(strcat(path2,"fluent/udf/emf7/src/electrodes.dat"),"r"))==NULL) { fprintf(stderr,"Erreur a l'ouverture du fichier electrodes.dat"); } fscanf(felectrodes,"%d",&NbreElectrodes); TabElectrodes=malloc(NbreElectrodes*6*sizeof(doubl e)); for(i=0;i<NbreElectrodes;i++) { for(j=0;j<6;j++) { fscanf(felectrodes,"%lf",(TabElectrodes+i*6+j)); } } fclose(felectrodes); } void calcul_force(double *x) { double B[3]; double E[3]; int i; calcul_B(x,B); calcul_E(x,E); prod_vect(E,B,F); for(i=0;i<3;i++) { F[i]*=conductivite; } } void prod_vect(double *A, double *B, double *C) { *C=(*(A+1)**(B+2)-*(A+2)**(B+1)); *(C+1)=-(*A**(B+2)-*B**(A+2)); *(C+2)=(*A**(B+1)-*B**(A+1)); } void calcul_B(double *x, double *B) { int i; int j; double k; double surf[6]; double tmpB[3]; for(j=0;j<3;j++) { *(B+j)=0; *(tmpB+j)=0; } for(i=0;i<NbreAimants;i++) { for(j=0;j<6;j++) { surf[j]=*(TabAimants+i*6+j); } k=surf[5]; yonnet(tmpB,x,surf,k); for(j=0;j<3;j++) { B[j]+=tmpB[j]; } } } void calcul_E(double *x, double *E) { int i; int j; double k; double surf[6]; double tmpE[3]; for(j=0;j<3;j++) { *(E+j)=0; *(tmpE+j)=0; } for(i=0;i<NbreElectrodes;i++) { for(j=0;j<6;j++) { surf[j]=*(TabElectrodes+i*6+j); } k=surf[5]/(surf[4]*surf[3]*(pow(unite,(double)2))*conductivite); yonnet(tmpE,x,surf,k); for(j=0;j<3;j++) { E[j]+=tmpE[j]; } } } void yonnet(double *C, double *x, double *surf, double k) { int i; int j; double xs[3]; double a; double b; double coef; double S[2]; double T[2]; double R[2][2]; double tmp[3]; for(i=0;i<3;i++) { xs[i]=(*(x+i)-*(surf+i))*unite; } a=*(surf+3)/2*unite; b=*(surf+4)/2*unite; coef=k/(2*pi); for(i=0;i<2;i++) { S[i]=xs[2]-(pow((double)-1,(double)(i+1)))*b; /* Attention les axes dans le yonnet et dans notre etude ne sont pas les mêmes */ T[i]=xs[0]-(pow((double)-1,(double)(i+1)))*a; } for(i=0;i<2;i++) { for(j=0;j<2;j++) { R[i][j]=(sqrt(pow(S[i],(double)2)+pow(T[j],(double)2)+pow(xs[1],(double)2))); } } for(i=0;i<3;i++) { tmp[i]=0; } for(i=0;i<2;i++) { for(j=0;j<2;j++) { tmp[0]+=(pow((double)-1,(double)(i+j))*log((R[i][j]-S[i]))); tmp[1]+=(pow((double)-1,(double)(i+j))*atan((S[i]*T[j]/(R[i][j]*xs[1])))); tmp[2]+=(pow((double)-1,(double)(i+j))*log((R[i][j]-T[j]))); } } for(i=0;i<3;i++) { *(C+i)=coef*tmp[i]; } } |
question about turbulence model selection and sensitivity | karananand | Main CFD Forum | 1 | February 26, 2010 04:41 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 03:20 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 06:19 |
Grid resolution for full-scale and down scaled model | gravis | Main CFD Forum | 0 | October 2, 2009 10:27 |
