August 18, 2001, 12:48 |
simulation of flat plate
i just try to make a simulation of flow on a flat plate and than i will compare the result with blasius, but the result is not really good enough,the value residual of residual error aproximately 5e-04 and it's never go down again although i have set the monitor's residual convergency for 1-e07, please give me any suggestion what should i do
August 19, 2001, 13:08 |
Re: simulation of flat plate
(1). I think I have posted a message on this issue before. (2). Go to Schlichting's book of "boundary layer theory", and study the Blasius solution both in ETA coordinate and physical x-coordinate. Plot the velocity profile from the leading edge of a flate plate. (3). Study the section "flow in the inlet length of a straight channel and a circular pipe", where a series of velocity distribution for laminar flow in the inlet section of a channel are given. Your mesh must be consistent with the velocity profiles. (4). In other words, even for the simple flat plate flow case, the solution and the mesh are highly non-uniform or stretched. (5). This is the place where analytical solution or series solution is ideal. (hard for numerical solution.) In other words, you are not going to get good solution, if you don't study the velocity profile development and create the mesh accordingly.
August 19, 2001, 15:55 |
Take a look at http://www.soton.ac.uk/~jimdate/froude.html
They seem to have a good solution compared to data using a RANS code CFX. |
August 22, 2001, 23:09 |
i have made a simulation , and then i compare with the experimental of blasius, but it seem only have a good result only in the leading edge area, can you explain this fenomena, or maybe there is another thing that i must to do?
September 12, 2001, 11:10 |
dear
sir, I want to know about flate plate and how to generate the boundary condition for solving the Navier stokes equation. |
Flow Over a Flat Plate | recon9 | CFX | 1 | January 20, 2011 21:09 |
Calculate Drag force for flat plate | vsun | FLUENT | 0 | October 3, 2010 07:56 |
Flat plate transition | RenardP | Main CFD Forum | 5 | April 8, 2010 01:07 |
Turbulent Flat Plate Validation Case | Jonas Larsson | Main CFD Forum | 0 | April 2, 2004 10:25 |
Supersonic flow over flat plate - best model | Chris Rand | FLUENT | 4 | October 3, 2000 06:58 |
