back flow total temperature
Like Tree11Likes
  • 2 Post By co2
  • 4 Post By MN
  • 1 Post By chauhan
  • 1 Post By Zigainer
  • 2 Post By jpo
  • 1 Post By thermal energy
Old   December 26, 2003, 21:29
Default back flow total temperature
co2
I have pressure outlet BC for a pipe. Let us say I specify Backflow total temperature as 300 K. I have a fluid flowing at 500 K. How does that backflow temperature affect my solution? If there is not backflow, is it true that even if I specify 400 K as the backflow temperature, that will not affect my solution?
Vinay94 and cessna172 like this.
Old   December 30, 2003, 13:58
Default Re: back flow total temperature
MN
As long as you have positive flow through the outlet, the backflow will not affect your solution; the backflow specifics are only there in case the solver sees reversed flow across the boundary, and thus uses that information for BC settings. Thus, you should keep the backflow conditions consistant with what you expect the output should be in temperature/composition in case there's the temporary case of reversed flow as to not cause the solver headaches, but you don't have to be exact. So specifying 300K or 400K shouldn't make a difference, but setting 5000K (5e3) may give you headaches in the iteration process.
Old   January 31, 2011, 12:40
Exclamation back flow temperature
Amit Chauhan
chauhan is on a distinguished road
hi,
I m still not clear with this. I am giving inlet temp as 500 K. and according to experiment outlet temp is 550 K. now in my simulation shall I give 550 K as back flow temp??? if not then my simulated outlet temp what i am getting is much lesser than that. now where is the problem???
suggestions invited.
Vinay94 likes this.
chauhan is offline   Reply With Quote
Old   April 24, 2012, 12:23
Alessio
alekso is on a distinguished road
maybe you can't "decide" your outlet temperature.
I modelling a wall heated gas solid reactor. But i have unphysical phenomenas... the colder gas in the center rise up, instead the hotter gas near the wall go down... what's the problem???
alekso is offline   Reply With Quote
Old   April 24, 2012, 16:06
Zigainer is on a distinguished road
Originally Posted by chauhanji View Post
hi,
so you still have backflow?
The thing is if you have a backflow temperature too high/low and you get backflow due to the simulation (I almost get backflow very time) a too wrong backflow temperature would cause some problems. If backflow later disappears it doesn´t matter, but if backflow does not disappear (that could be because of the wrong backflow temperature) you have a problem.....
Vinay94 likes this.
Zigainer is offline   Reply With Quote
Old   April 24, 2012, 17:20
jpo
jpo is on a distinguished road
Post #2 is right
Your backflow temperature setting doesn't influence your solution. The pressure setting does.
Thus, if you really have backflow, only then the backflow temperature setting will be important, because fluid with the requested backflow temperature will start entering your computational domain
jpo is offline   Reply With Quote
Old   July 17, 2014, 04:02
Default backflow
thermal energy is on a distinguished road
hi all,
ı have an rectangular geometry (lenght:76, width:27 mm). heat flux is applied from one of the vertical walls. ı have velocity inlet BC at lower part and also pressure outlet BC at upper part. velocity magnitute is zero (0) (no forced convection), initial gauge pressure is also zero and temperature is 298 K at velocity inlet BC. also, for pressure outlet BC gauge pressure is 0 and backflow temperature is set 298 K. initial temperature is also 298K.
the problem is that reversed flow occured.
"reversed flow in 34 faces on pressure-outlet 17"
the solution is converged but ı am not sure it is right or not.
any suggestion. thanks for you time.
Vinay94 likes this.
thermal energy is offline   Reply With Quote
back pressure at exit for supersonic flow BigFrank FLUENT 6 April 24, 2014 15:13
static temperature is higher than total temp. in buoyancy problem amirbahador FLUENT 2 October 24, 2010 07:21
Total pressure and temperature, isentropic Chris FLUENT 0 January 16, 2003 05:30
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 2, 1999 23:18
