problem on DEFINE_DPM_OUTPUT
I am now working on a discrete phase flow and like to export the velocity magnitude of gas along each particle trajectory. It seems that using DEFINE_DPM_OUTPUT is the best way. However, when compiling the "Melting Index Along a Particle Trajectory" example in Fluent UDF user guide, I always met the compile errors, like "parse error", "structure reference not implemented", or "sprintf: undeclared variable", etc. Do you have any experience on it ? I really appreciate your info. Thanks, Xubin |
Re: problem on DEFINE_DPM_OUTPUT
Hi Xubin, Isn't it enough for your problem to activate the "Step by Step" Report Type in the menu "Particle Tracking"? Than you will receive a file with all particle positions and velocities. You can import these data into Excel.
Wolfgang |
