Home > Forums > FLUENT
convergence
Old   October 5, 2001, 07:53
Default convergence
Paulina
Old   October 9, 2001, 19:49
Default Re: convergence
Chetan Kadakia
where is your question?
Old   October 10, 2001, 04:06
Paulina
Hello! I'm sorry for last message, but I had a problem with sending it.
I wrote my case early, so now I will only remind it in a few words. I have a problem with my simulation, exactly with convergence.I have a very high residuals. I'm modeling liquid-liquid systems (dispersion)in the static mixers. The first fluid is a water and the second one is an engine-oil, with the density 920 [kg/m^3]. I use an Algebraic Slip Model in Fluent 5.4. The flow is turbulence, so I have also two additional parameters: k and epsilon. I tried to solve my problem many times and to do this I made many steps. Once I changed the solve controls, I decreased them to the level about 1e-03. But it doesn't help.Last time I started my calculation from 1e-06 for k and epsilon and the another parameters for example slip velocity about 1e-04. Unfortunatly I haven't got a solution. Also I should tell that I modeling this case for laminar flow and I obtain a solution very quicly. So I can't understand my problems with this case. I know that the main problem is with the k and epsilon. To simulation I use the "multigrid solver". I know that it isn't easy case because I have very complicate static mixers, but what should I do to obtain a convergence. At the moment I try to solve my case modeling only with turn on flow, volume fraction and slip velocity in the "solve controls" without turbulence. At the moment I can not say if it will help, because it require a time. I would appreciate any suggestions! Thanks! Best regards! Paulina
Thread Tools
Trackbacks are On
Convergence Centurion2011 FLUENT 27 February 7, 2016 12:58
problem with Min/max rho tH3f0rC3 OpenFOAM 7 February 23, 2013 06:37
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
