October 3, 2001, 02:55 |
Gambit on windows 2000
Hellow
I was wondering to ask if anyone has faced a problem with the installation of gambit 1.3 on windows 2000 (service pack 1): The case is. The software run indicates that it cannot find exceed x server even though exceed 6.2 and exceed 3D are both installed in the registry and the path is ok. Is gambit unable to locate exceed on its own or shall i try to run it from somewhere else. Regards Costas |
October 3, 2001, 05:15 |
Re: Gambit on windows 2000
It works fine for me.
Have you set your enviornment variables for Fluent before opeing the command prompt to run gambit? In my case gambit brings up Exceed and then I select a passive mode. You can change this via exceed. Greg |
October 4, 2001, 09:01 |
Hi.
After installation of Gambit1.3, two executive files are made in Flunent.inc folder. If you click the file(gambit.exe) in FLUENT.INC\gambit1.3\ntx86\ folder, gambit is not work. Maybe, you can play the gambit using the file(gambit.exe) in FLUENT.INC\ntbin\ntx86\ folder. |
October 22, 2001, 07:15 |
I have met the same trouble, although I have set the PATH and run the right gambit.exe. Will anyone tell me the way to solve it?
October 22, 2001, 12:38 |
hi.
I sorted out the problem by installing service pack 2. Then you need to install atleast exceed version 6.1 for nt. Try to run the exe from c/fluent/ntbin/nt86. because there is anotherone created at c/fluent/gambit1.3/ntbin/nt86. |
October 23, 2001, 03:21 |
I have done all the things you metioned. But, there is the same error. Can you give me some suggestion?
Display Modes | |
Fluent and Gambit on Windows 7? | gholamghar | FLUENT | 12 | July 10, 2012 10:42 |
Fluent 6.2 & Gambit on Windows XP x64 | AcoidanBM | FLUENT | 9 | October 30, 2011 14:08 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Gambit on Windows 98 or 2000 !!! | LOTFI | FLUENT | 5 | February 15, 2004 13:05 |
