Sinclair Model + secondary turbulence
Old   October 26, 2001, 13:37
Default Sinclair Model + secondary turbulence
Yi
hi,
I met a problem when simulating two-phase flows using Sinclair model + secondary turbulence model in FLUENT4.5.6.
1> Turn on (Sinclair model + secondary turbulence). However, the equations to solve do not include particle-phase k & epsilon automatically.
In this case, the simulation gives very good results!
2> Turn on (Sinclair model + secondary turbulence). Also, include particle-phase k & epsilon in the equations to solve.
This time, the (time-dependent) simulation diverges!
3> only turn on Sinclair model (without secondary turbulence)
The simulation results are not good.
Can anybody tell me what is the difference between case-1 and case-2? I tried to seek more details in FLUENT manual, but can't find the answer. I want to clarify the governing equations and auxillary relations employed in the simulation.
Thanks a lot in advance.
Adding a Turbulence Model doug OpenFOAM Running, Solving & CFD 11 May 21, 2018 13:54
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
