-   -   Unsteady flow (http://www.cfd-online.com/Forums/fluent/29020-unsteady-flow.html)
Ali October 25, 2001 13:28
Unsteady flow
Dear Fluent Users,
I am running an unsteady supersonic flow directed on the surface. This is the first time I have attempted the unsteady calculation and I am having a considerable difficulties in converging the residuals to the desired level.I have even reduced the time step size as low as 10^-08 and got nowhere with it. Is it the rexation factors or something else that I need to mannipulate to achieve my goal.
What my final goal is to measure the oscillating time period of the blunt body shock on the surface, due to its pressure fluctuation.
Is any body out there who has attempted these kind of CFD models before and know more than I do and one last thing; how do I postprocess the data to simulate this phenomena.
Thank you guys very much in advanced. I am hoping for some excellent answers from you experts.
Axel Rohde October 27, 2001 16:20
Re: Unsteady flow
Although I am not a Fluent user, your question did strike my interest. Can you be a bit more specific about your problem setup: Is the flow 2-D or 3-D? What is the free-stream Mach number? What is the size of your plate? How does the unsteadiness come in?
reza pegah October 28, 2001 16:52
Re: Unsteady flow
david October 29, 2001 08:38
Re: Unsteady flow
A) Have you checked even though ur residuals are not of expected level, still it may represent the right solution? B) for unsteady solution, animation of representative properties would be good to show
Ali October 29, 2001 12:46
Re: Unsteady flow
Hi Axel
The problem is 2D axisymmetric and the free stream Mach number is around 2. The fluid is ejected from a 1mm nozzle and the plate is infinately long. The flow is impinging on the slot. i.e this is same as the Hartmann-Springer affect. The shock wave on the surface oscillates due to pressure fluctuation on the surface. This phenomena is real and highly validated over the years, but I would like to model this in CFD any thought.
Thank you Ali
Ali October 29, 2001 12:48
Re: Unsteady flow
Hello David,
Have you tried to show any fluid property animation with your work. If so can you pass on some hint this way please.
Thank you
Ali
Axel Rohde October 30, 2001 08:21
Re: Unsteady flow
Ali,
Thanks for the description. I am not familiar with this setup, particularly the Hartmann-Springer effect. Do you have a web reference of some sort where I can read up on this? - Also, is this plate horizontal? If the free-stream flow is Mach 2, what is the velocity of the jet (or is the jet velocity at Mach 2)? At what angle does the jet impinge on the plate?
By the way, I publish a shareware program 'MicroTunnel' that deals with 2-D unsteady compressible aerodynamics. Here a link to a transonic flow over a prism (Mach 0.9) with alternating shock shedding,
www.microcfd.com/prism.htm
The program is still in its development stage. I am currently implementing a cut-cell interpolation algorithm for smoother flow over curved surfaces (airfoils). For rectangular geometries, such as horizontal/vertical plates it is well suited, although a 'jet' could only be added by modifying the source code.
Axel
Ali October 30, 2001 10:40
Re: Unsteady flow
Dear Axel
The jet Mach No. is 2 and the jet is directed perpendicular to the interaction surface. The jet is exausted in to ambient air. The CFD result indicates that pressure absolute rise downstream of the blunt body shock is as much as 4.5 bar/atmosphere.
As far as the Hartmann-Springer effect is conserned,there is very little information available to me, but there are few research institutes that are involed in this line of work. May be you may find some information at the webb sight below.
http://info.fysik.dtu.dk/struktur/morch.html
P.S. What was the time duration of your simulation cycle for the prism ?
Good luck, happy hunting
Ali
Axel Rohde October 31, 2001 09:25
Re: Unsteady flow
Ali,
Thank you for the link. I now understand the setup of your flow. Your stability problem may have to do with the fact that the surrounding air is stationary. My shareware MicroTunnel evolved from a code that was used to study transient supersonic jets exiting into a subsonic or supersonic free stream. I just started the old Jet program, and a free stream Mach number of M = 0 is not an option (M = 0.1 being the lowest). I will look into that when I get a chance.
About the unsteady simulation ( www.microcfd.com/prism.htm ):
The animated GIF is a closed loop of about 50 frames (48 I think). The unsteadiness is periodic, although the closure at the end of the loop is not 'perfect' as you may have noticed. The first frame of the simulation is shown in,
www.microcfd.com/gallery/prism-trans-m.htm
which also gives you all the test setup data including dimensions. The entire simulation time frame of one 'period' is 5ms (milliseconds), as indicated by the Run Time (0.045s) and Stop Time (0.050s) in the window. The indicated Time Step of 0.10ms is the time interval in between each graphical update, NOT the integration time step (which is about 5 microseconds). Thus each of the 50 frames in the animated GIF is 0.10ms apart.
MicroTunnel marches explicitly in time, and to integrate 1ms takes about 5 minutes on a 1GHz Intel Pentium III (AMD are faster). So the entire simulation (5ms) takes about 25 minutes to compute. Keep in mind that you have 800x600 = 0.48 million cells, and that each pixel on the (800x600) display represents exactly one cell in the Cartesian mesh. I would be curious how long Fluent would take to run this using an inviscid solver at the same resolution.
Axel
