solid-liquid suspension with multi-reference frame
Old   October 25, 2001, 14:47
Default solid-liquid suspension with multi-reference frame
Min-Hua Wang
Hello, All:
Does anybody have experience in the simulation of the stirred tank for solid-liquid suspension with multi-reference frame.
Thanks
MHW
Old   October 29, 2001, 04:00
Default Re: solid-liquid suspension with multi-reference f
Alain
I do,
what is your question ?
Old   October 29, 2001, 11:39
Min-Hua Wang
Thanks.
I am working on CFD simulation for a stirred tank without baffle blade. I was using Mixsim to setup multi-reference frame and to start single phase simulation. The working fluid is water. The convergency is good. Then I run two-phase simulation withing fluent 4 environement. The solid has 200 micro meter in size and the solid density is 1200 kg/m^3. Volume fraction f solid is about 15%.
I run simulation in time transient flow with Eulerian (Granular) model. Also I selected Gidaspow model for granular viscosity. Schuh model is selected for Drag force. The rest I left tehm by default data.
How do I justify the final solution. I always observed that the mass residual is very hard to be reduced. The suspension of solid seems to me not developed. How long should I run the simulation.
Can you suggest me some experience? Many thanks. MHW
Old   October 29, 2001, 13:59
Alain
Hi MHW
I did a simulation very similar to yours a couple years ago. Multiphase model can be very difficult to handle, depending on your flow condition.
First of all, if you don't have any baffle you can run your problem as a single rotating frame. This may help your convergence.
You should underelax your interphase momentum exchange term even if you run a transient simulation. it may help to suppress this momentum exchange at the begining of the calculation.
In some case you'll need to deactivate multigrid for pressure. Convergence is longer but the space marching solver is more stable than the MG solver for multiphase calculation.
At last, I will suggest you to lower your time step. if your calculation is too long and you are looking for the steady state solution you can also make fewer iteration in each time step.
I hope this could help you.
Alain
Old   October 30, 2001, 11:54
Lanre
MRF is a steady-state model ONLY, hence, is incompatible with the Eulerian-Granular multiphase model in FLUENT 4.
Since you have no baffles, delete the MRF zone and convert to a single frame of reference (See FLUENT 4.4 Users' Guide). Now you can solve the transient mixing and include the Eulerian-Granular model for your multiphase calculations.
Old   October 30, 2001, 20:56
Min-Hua Wang
Now can i use MRF model and Eulerian-Granular model in steady state simulation?
Thanks.
Old   October 31, 2001, 04:28
Alain
Yes you can use these models in steady state simulation but convergence can be very difficult to reach.
As Lanre said, if your tank has no baffles, you do not need a MRF approach, a single rotating frame will be more correct as it can be use in both transient and steady state.
A point about MRF and transient simulation : MRF is a steady state approach so it is true that you may have no significant results if you use it for a transient simulation. Nevertheless you can use it in a transient simulation if you are looking for steady state solution : the intermediate, time dependent, solutions may be not significant, but the converged, steady state solution does.
Best regards
Alain
Old   April 30, 2010, 18:22
Tantular Nurtono
tantular is on a distinguished road
Please observe the solid volume fraction during the iterations. I have problem that the solid volume fractions decreased during the iterations. After the iterations converged, the solid volume fractions is different with the initial value when I patched in the beginning of simulation.
tantular is offline   Reply With Quote
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 04:28
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
