user-defined-function problem
Old   November 6, 2001, 08:04
Default user-defined-function problem
kevin
i have many problem recently,about fluent's user-defined-function , for example : new subroutines are written to calculate the chemical reaction for this simulation , i used fluent's macro [DEFINE_UDS_FLUX(name ,face,thread,i)],but manual isn't explain kind of i vlave ,is zero or anynumber or anyword ~????
Old   November 6, 2001, 16:18
Default Re: user-defined-function problem
fawzy
hi
DEFINE_UDS_FLUX (name, f, t, i)
i is integer : is the name of the UDF specified by you: i = 0 is associated with udf scalar-0
Old   November 7, 2001, 21:24
Greg Perkins
This function is for defining the convective flux in the sclaar transport equation. For most cases you won't need to change from the default method and thus you normally won't need to use it.
For chemical reactions etc., the source term udf is most likely the best way to add sources of chemical species, energy and mass to the conservation equations.
If you want more info on this routine reply.
Greg
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
particle diameter (user defined function) eulerian nasser FLUENT 0 June 18, 2006 03:39
User defined function of mass flow rate Eric FLUENT 1 April 22, 2005 18:15
User Defined Function for convection coefficient ereiss FLUENT 1 July 8, 2004 16:10
Help: user defined function alice FLUENT 3 December 13, 2000 00:10
