-   -   How to create an inclined isosurface in 3D ? (http://www.cfd-online.com/Forums/fluent/29070-how-create-inclined-isosurface-3d.html)
Sridhar November 13, 2001 02:59
Hi Fluent users,
I am studying the flow in a 3D elbow pipe with circular cross-section, I want to study the results at the circular face which divides the elbow pipe excactly into two parts. actually this face is inclined at an angle of 45 degrees to x and y.Do I need to use isosurface?? Is there any option in fluent to create such faces, or do I need to create it in gambit. Can anybody assist me?
Thanks.
glenn creten November 13, 2001 04:50
Re: How to create an inclined isosurface in 3D ?
I would create an isosurface from a 'custom field function', e.g. x+y=constant. This will create the desired surface.
Good luck!
Erwin November 15, 2001 17:35
In the
Surface... -> Plane...
panel you can simply define planes in any direction you need.
Sridhar November 15, 2001 20:00
Thanks Erwin. I figured it out.
