interface warning message when running parallel
Old   November 16, 2001, 10:22
Default interface warning message when running parallel
Kang
I tried to run a model which contains a pair of interfaces using the parallel version of FLUENT. When reading in the case file, FLUENT generates some warning messages about "interface encapsulate...", does it mean I have to partitioned the grids such that the Interfaces are in a single partition?
Please advise. Thanks.
Old   November 16, 2001, 11:23
Default Re: interface warning message when running paralle
Jonas Larsson
When you partition the case you have to de-select "partition across zones".
Old   November 21, 2001, 13:00
Karl
I had that problem also. Took a considerable amount of time to resove the problem, trying many things. Ultimatel, the issue was resolved by using Fluent 5.7.
Also, Make sure you create the interface 'before' partitioning the mesh, and partition the mesh in the serial solver.
Old   November 23, 2001, 04:32
Volker Pawlik
also Fluent 5.4 has no problem with interfaces. So the way is to partition the grid with 5.4 and read it into 5.5
Volker
How to use setField to create sphere sega OpenFOAM Pre-Processing 38 January 13, 2022 00:39
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
OpenFOAM14 for Mac OSX Darwin 104 gschaider OpenFOAM Installation 118 July 20, 2008 05:19
[OpenFOAM] Could you please help me liugx212 ParaView 4 December 22, 2005 16:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
