November 25, 2001, 07:04 |
Gambit - meshing question
I have a simple cubic box. On the top surface of the box, I have several inlet holes. And, on the opposite side of the cubic box (bottom surface), I also have identical inlet holes (same sizes located at the relative positions). I can easily mesh the top surface. How can I use this mesh and propagate toward the bottom surface? Cooper scheme does not seem to work becasue the un-meshed source surface needs to be ONE complete surface (in my case, I have the main surface + the inlet holes). Any suggestion will be highly appreciated. Pei |
November 26, 2001, 10:08 |
Re: Gambit - meshing question
Create cilinders from top holes to bottom holes. Split cube with cilinders. All volumes can now be coopered.
[ANSYS Meshing] ANSYS Meshing vs GAMBIT | aerospain | ANSYS Meshing & Geometry | 0 | September 28, 2011 06:05 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! | lau06165 | ANSYS Meshing & Geometry | 1 | March 22, 2010 01:09 |
Meshing Aircraft with Gambit | Ed | FLUENT | 5 | November 9, 2004 05:04 |
