Gambit - meshing question
Old   November 25, 2001, 07:04
Default Gambit - meshing question
Pei-Ying Hsieh
I have a simple cubic box. On the top surface of the box, I have several inlet holes. And, on the opposite side of the cubic box (bottom surface), I also have identical inlet holes (same sizes located at the relative positions). I can easily mesh the top surface. How can I use this mesh and propagate toward the bottom surface? Cooper scheme does not seem to work becasue the un-meshed source surface needs to be ONE complete surface (in my case, I have the main surface + the inlet holes). Any suggestion will be highly appreciated.
Pei
Old   November 26, 2001, 10:08
Default Re: Gambit - meshing question
Erwin
Create cilinders from top holes to bottom holes. Split cube with cilinders. All volumes can now be coopered.
[ANSYS Meshing] ANSYS Meshing vs GAMBIT aerospain ANSYS Meshing & Geometry 0 September 28, 2011 06:05
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 01:09
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 05:04
