-   FLUENT (
-   -   contour plot--surface integral (
Theju December 4, 2001 00:59
Can anybody help me out in this problem... first the contours of temperature on a blade surface was plotted..the temperature was as expected..then mass-wieghted temperature (surface integral)was calculated on the blade was ZERO K! ,when again temperature contour was plotted again it was ZER0 K! throught on the blade exit fluent without saving this case and repeat the process all over again but to see the same results..
Regards Theju
Jin-Wook LEE December 5, 2001 23:55
Re: contour plot--surface integral
It's clear because velocity in the wall is zero. For your case, I recommend that you use 'area weighted average'. See the definition of 'mass weighted average' in the manual or fluid dynamics textbook.
Sincerely, Jinwook
