Home > Forums > FLUENT
DPM
Old   December 5, 2001, 20:27
Default DPM
Sam
When should you run a couple solution (so that the particle injections effect the flow)? Are there any rules of thumb?
Old   December 5, 2001, 20:34
Default Re: DPM
Jin-Wook LEE
Of course there is a rule of thumb. The most important parameter is,
(solid mass flow rate) / (gas mass flow rate).
As far as I remember(I've forgotten the reference), when the ratio exceeds 0.2, the interaction between gas and particle should be interacted.
You can simply test it by increasing the solid mass flow rate continuously.
Sincerely, Jinwook
Old   December 9, 2001, 14:34
Default Re: DPM
Alain
You also need to take into account a two way coupling if particles introduce mass, momemtum or heat source.
I sugest you to take a look at this book : Multiphase Flows With Droplets and Particles Clayton Crowe, Martin Sommerfeld and Yutaka Tsuji
It will enlight you on DPM flow modelling.
Best regards
Alain
Thread Tools
Trackbacks are On
DPM and UDS mighelone FLUENT 0 June 3, 2011 07:27
DPM modeling Mohsin FLUENT 0 March 31, 2010 22:11
DPM - do the particles affect the liquid? Nikhil Dani FLUENT 0 January 1, 2009 12:58
slow after mesh for enhanced wall treat DPM joshkemp FLUENT 0 May 1, 2007 17:20
compatibity LES with DPM Alex Munoz FLUENT 0 March 26, 2003 22:13
