November 9, 2001, 15:17 |
Two phase flow problem
I am trying to solve an isothermal, laminar, and steady 2D two phase (Air-water) flow problem using Fluent 5.4. The used multiphase model is VOF and the model scheme is implicit. Simply the flow problem represented by a liquid water filled an enclosure and it is driven by a stream of air. Could you please help me to solve the following error: Error: Internal error at line 1645 in file 'sg_mphase.c'. bc type not handled Update_Fluid_Density Error Object: () and what do you recommend me in solving this air-water problem Many Thanks, M. Shannag |
November 11, 2001, 22:21 |
Re: Two phase flow problem
Are you using a UDS? Anyway search about the difficulties and advising given in other posts on this forum.
Rgds Newbie |
December 29, 2001, 12:43 |
can you e-mail me your cas and dat files
Display Modes | |
error in two phase flow problem | mvee | FLUENT | 0 | March 28, 2007 05:17 |
LES on two phase flow | Li Yang | Main CFD Forum | 0 | May 12, 2004 08:10 |
Two-phase/ Single phase mix flow | Reza | Main CFD Forum | 1 | August 6, 2003 06:36 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
Poiseuille flow problem | Rosie | FLUENT | 1 | December 6, 2002 16:52 |
