Internal Error
Old   December 4, 2001, 13:16
Default Internal Error
Stephen
I am running a combustion case. My case runs well when I am using the first order for my residuals. But when I switch them to second order the case will run for about 100 iterations and then I get this error.
Error: Internal Error at line 743 in file 'amgif.c' divergence detected in AMG solver Error object: ()
Can anyone tell me what this means and what I can do to correct this problem? Like I said the case runs perfect when I am using first order, but it only does this in second order. I have also set my under-relaxations to a very low value of 0.1.
Old   December 5, 2001, 02:31
Default Re: Internal Error
Armin Gips
I think it means that the solver finds no solution so it stops the iteration. I had the same probleme, I forgot to scale my geometry. Did you scale it?
Yours Armin
Old   December 5, 2001, 15:20
Stephen
Yes I scaled it. All the measurments are correct. I'm running it using a under relaxation of 0.1 and using first order for all my residuals and everything is running fine and all my residuals are decreasing. However I am still afraid to try second order since the same thing will happen.
Old   December 10, 2001, 06:13
José Carlos Espinosa
Hello Stephen. The error what appears is the typical error of divergence solution. When the boundary conditions are very critical the convergence of the solution is difficult. For example when I begin a calculate, I usully make it step by step. First I turn off equations of energy and turbulence, first order upwind and low parameters of under relaxation. With this previous calculate convergence, I turn energy and turbulnce equation but I continuous with low parameters. When the solution is convergence again, go up the parameters "in default". And finally after this solution I turn second order for the pressure and momentum variable. Sometimes I conect second order for turbulence and for energy, if the calculate is necessary. Thus, step by step simulation can not convergence with second order solution,and first order solution can be Ok... Regards JC PD: Excuse me my English, please...
Old   December 11, 2001, 23:05
Stephen
Thanks I appreciate the help. The case is working well in first order still. I'm going to run it for a while until I switch it to 2nd order.
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
