Home > Forums > FLUENT
Fluent on win98?
Old   December 12, 2001, 03:47
Default Fluent on win98?
Giovanni
I would like to know if Fluent runs correctly on Win98.
Thank you Giovanni
Old   December 12, 2001, 04:27
Default Re: Fluent on win98?
Jin-Wook LEE
Some users try and sometimes it works on Win98. But, basically, 'NO', especially for new version.
Sincerely, Jinwook
Old   December 12, 2001, 04:53
Giovanni
Do you mean that Fluent sometimes commits calculating errors ?
Thank you Giovanni
Old   December 14, 2001, 13:55
Scott Whitney
If you can get it to run on Win98 you will be fine (I do it all the time when I give presentations and the computer available doesn't have NT or 2k). The calculations will not change - you will not have different results. However it can sometimes be difficult to get Fluent to load the first time. Gambit is virtually impossible on Win98.
Old   December 14, 2001, 18:00
Scott Whitney
I forgot to add this: getting 512 MB of memory or more to run on Win98 requires a trick. And that trick may slow the machine significantly. Thus you can only get 2D models or rough 3D models to run well on Win98.
Old   December 17, 2001, 10:51
Giovanni
Thanks you very much!!!
Giovanni
Old   December 18, 2001, 03:43
Jin-Wook LEE
Thanks a lot, too.
Sincerely, Jinwook
Old   February 4, 2002, 19:56
Lu Hu
I tried to run Gambit on WinME long time ago. Seems you need to edit autoexec.bat and add some environmental variables by yourself. If you are using win2K, the installation program will do it automatically.
Thread Tools
Trackbacks are On
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 7 May 22, 2014 22:30
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 4 September 20, 2013 16:30
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 03:57
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
