Home > Forums > FLUENT
supersonic pressure?
Old   December 19, 2001, 04:38
Default supersonic pressure?
Giacomo
Hallo,
I'm trying to analyse a simply convergent nozzle. I do not know if the flow becomes supersonic (probably no, ptot-in is 1.5*ptot-out).
I would like to know what is supersonic pressure in pressure inlet boundary condition and how I can estimate it.
Thank you very much
Giacomo
Old   December 20, 2001, 17:20
Default Re: supersonic pressure?
petra
In my opinion, supersonic initial gauge preesure is used for initilazation under solve initialize. And in case of a closed supersonic area in the flowfield, where the information from the outlet can not go back to the inlet, it is used as staic pressure at the inlet.
Old   December 20, 2001, 19:05
jim clancy
For convergent nozzle the flow will not be supersonic, by using the compressible flow tables of 1D flow you might estimate the Mach number according to the contraction ratio..good luck.
Thread Tools
Trackbacks are On
UDF to define or adjust pressure??? engahmed FLUENT 0 July 6, 2010 17:19
pressure BC-natural convection engahmed Main CFD Forum 0 June 16, 2010 11:38
pressure in Natural convection??? engahmed FLUENT 0 June 14, 2010 12:51
pressure inlet & outlet. help ASAP Plz engahmed Main CFD Forum 0 June 13, 2010 15:34
Pressure Inlet yields wrong velocities Ben FLUENT 0 November 21, 2004 02:47
