Home > Forums > FLUENT
swirl factor
Old   December 21, 2001, 08:15
Default swirl factor
zhang
Hello everyone, I solved the swirling flow in cyclone, after I turned on the Swirl dominated flow option on Viscous Model Panel, how can I define the value of Swirl Factor? Please help me ,thank you .
Old   December 26, 2001, 05:23
Default Re: swirl factor
Jin-Wook LEE
As far as I know, it's optimization parameter. That is, it should be optimized(or calibrated) to the your flow situation.
And, as far as my experience is concerned, RNG model is not good approach for cyclone analysis(for me, cyclone separator). RSM shoud be applied to solve swirl characteristics, especially, swirl velocity. By using k-e RNG model, 'angular momentum conservation' was not observed.
Sincerely, Jinwook
Old   January 16, 2002, 02:23
david
Jinwook... can you please make comment on the capability of 'angular momentum conservation' of k-e Realizable model ? DC
Old   April 23, 2012, 09:18
Narges Mohsennia
NMohsennia is on a distinguished road
Hello.do you work in fluent program?is it your question:you want to know how you can use swirl factor in fluent?
NMohsennia is offline   Reply With Quote
Old   July 24, 2012, 09:05
Ali nabavi
Ali.nabavi is on a distinguished road
Hi friends
Im modelling the swirling impinging flow. i dont how could i find the optimum value of swirl factor. im using K-E RNG. i should mentioned by suing RSM my solutions dont converge ( they diverge).
Tanx...
Ali.nabavi is offline   Reply With Quote
Thread Tools
Trackbacks are On
swirl factor hossein802 FLUENT 0 February 27, 2010 07:57
Swirl in Pressure Swirl Atomizer varunrajendra FLUENT 0 August 19, 2009 12:09
Quantifying Swirl Ianto Main CFD Forum 0 April 27, 2009 10:54
Swirl Factor (RNG k-e Model) Neil FLUENT 0 March 12, 2007 18:00
Swirl in backflow on pressure outlets Jonas Larsson FLUENT 17 February 3, 2000 03:14
