Grid problems
Old   January 15, 2002, 02:36
Default Grid problems
Christian
Hi.
In meshing my GAMBIT model I have encountered the follwing message:
Impossible edge mesh/face scheme combination. Turn mesh_flags_incremental_display default on.
I don't know how to turn this on, and the manual is not much help. Does anyone out there know the answer ?
Christian
Old   January 15, 2002, 09:55
Default Re: Grid problems
phil
go to EDIT in top left corner of screen. click on DEFAULTS click on MESH click on FLAGS radio button then set incremental_display variable to 1
Old   January 15, 2002, 16:13
Erwin
First of all, this message is part of a number (3) of possible causes of failure. Usually when I get this error message I have a problem with my vertex types: for example, I want to create a mapped mesh on a face, but the vertex types are screwed up (you need 4 vertices called 'E' at logical locations to create a mapped mesh).
Check your vertex types by selecting the face, and see if they match with what you really want to do. If there is a problem, you can change the vertex to the appropriate type in the 'Set face vertex type' panel (second from the right).
Old   January 16, 2002, 02:55
Christian
Thank you, Phil and Erwin
Questions for a species transport problems (snapshots attached) aleisia FLUENT 2 October 9, 2011 04:40
grid on a circle HaKu Main CFD Forum 4 April 15, 2010 11:56
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 14:17
"grid points" or "grid interface" ztdep Main CFD Forum 1 June 6, 2007 15:00
Problems in grid generation in ICEM Tim CFX 1 September 30, 2006 06:43
